Hi dougalzeb
there isn´t something like GO+ GO- on the desk the only thing you can do is to press the - button twice before pressing go.
cheers
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
As Haytech says, press the '-' key twice and ten GO, or if you have an external keyboard attached, enter the memory number directly, Enter and then press the GO button.
Only problem with this (as I found last night) is that if there is a gap in the programmed Memory numbers then two minus keys don't take you back far enough. I know you can enter the number on the keyboard and you can see on the monitor which memories are actually programmed but in the heat of the moment the instinctive response or "minus minus go" failed me :cry:
Lee Stoddart
