Fann in Fan out
blackwald
Hello
I want to fan in/out 8 of the same fixture.  I push Z/shift and use the pan Encoder. Instead of getting a symetrical Fan/Spot all Fixtures fan completly to the right or to the left,  If i look at the Grid, they fan from the middle axis complety to the right or left, instead half to the right, half to the left. What do I make wrong?
Thank you
This is because by default, the Fan mode for position is set to "Fan First". To change the fan mode to achieve what you are looking for, hold SETUP and tap the Position tab on the touchscreen (this will appear when you have a moving fixture selected). This will open the Position Options, where you can hold Z/SHIFT, and choose "Fan Middle", so that the red stripe changes from Fan First to Fan Middle. Release SHIFT, and press OK on the window.
Now when you hold Z/SHIFT and dial the Pan/Tilt encoder, your selected fixtures will be fanned from the middle.
Hope this helps, any queries let me know.
