Simonkbike Posted January 20, 2019 Report Share Posted January 20, 2019 Hi, Trying to find or create a fixture file for some generic RGBW moving head fixtures for use with Solution desk running 7.9.4 ZeroOS. I have looked at Stagg MHB-HH20 which is nearly the same, containing pan, tilt, RGBW colours and in 9CH and 14Ch modes as is my unit. Struggling with the Fixture Editor assigning my "Master Dimmer" parameter to a fader. In my manual, the "Brightness" channel is split into three DMX address sub-sections : 0-7 = OFF8-134 = Master Dimmer 135-239 = Strobe 240-255 = Open I seem to recall there's a way to assign the sub-addresses 8-134 to separate channels but struggling to work it out tonight. Might also be helpful to put the Strobe on a separate channel. Any help gratefully received to create a file with the sub-address assigned to a fader. Thanks all, Simon PS. When I get it connected there may be more questions ! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 20, 2019 Report Share Posted January 20, 2019 Hi Simon, 11 hours ago, Simonkbike said: Struggling with the Fixture Editor assigning my "Master Dimmer" parameter to a fader. In my manual, the "Brightness" channel is split into three DMX address sub-sections : 0-7 = OFF8-134 = Master Dimmer 135-239 = Strobe 240-255 = Open I seem to recall there's a way to assign the sub-addresses 8-134 to separate channels but struggling to work it out tonight. Might also be helpful to put the Strobe on a separate channel. For this, your best bet is to create this as a “Shutter” parameter, with a default value of 134. Then tick the “Scale by Virtual Intensity” box for the parameter. Then add a Brightness parameter named “Dimmer”, with a default of 255, and tick the “Virtual Parameter” box. This will grey out the DMX address field. This dimmer will then by default scale the shutter parameter between 0-134, giving you a dimmer. If you do then need to access the strobe, you can then adjust the Shutter parameter. There isn’t a way to split a parameter, but this method should achieve what your after. Hope this helps and makes sense, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
