ChristianFLXs Posted January 13, 2019 Report Posted January 13, 2019 Hi All Im wondering if it’s possible to amend the output on the external monitor? Currently it displays queus for the master playback. I want to be able to view and edit the playbacks on the faders(the console screen gives little detail) thanks in advance christian Quote
Edward Z88 Posted January 13, 2019 Report Posted January 13, 2019 Hi Christian, To view different playbacks in the cue list window, make sure your faders are in Playbacks function, then hold VIEW and tap the playback's button you wish to view. This will then bring the cues stored on this playback into the cue list window. A single press of VIEW will show you your faders window, rather than cue list. If you are finding this is only changing what is displayed on the internal touchscreen, press SETUP -> System Settings -> External Monitor -> Enabled. This will then allow the VIEW key to adjust the external monitor. Hope this helps, any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
ChristianFLXs Posted January 13, 2019 Author Report Posted January 13, 2019 Brilliant!! Thank you Edward, that helped heaps. Cheers Christian Quote
Edward Z88 Posted January 13, 2019 Report Posted January 13, 2019 Hi Christian, 33 minutes ago, ChristianFLXs said: Brilliant!! Thank you Edward, that helped heaps. Cheers Christian Great, glad to hear it. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
