NickGR Posted January 12, 2019 Report Share Posted January 12, 2019 With Jester ML 24, is it possible to compose a scene in Run Mode using sub-master faders that I have previously programmed, and then Program the combined output to a Memory? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 12, 2019 Report Share Posted January 12, 2019 Hi Nick, No this isn't possible. What you can do however is playback a Submaster in Run mode, hold SHIFT and tap the Submasters button, tap EDIT, and then add in any extra channels or fixture's to create your scene. Then use the Up/Down arrows to choose the memory to program, and hit the red PROGRAM button to store. You will then be taken back to Run mode. This is also the method you can use to copy submasters to memories and vice-versa. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
NickGR Posted January 13, 2019 Author Report Share Posted January 13, 2019 Thanks Edward. Good to know. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 13, 2019 Report Share Posted January 13, 2019 45 minutes ago, NickGR said: Thanks Edward. Good to know. No problem. If you have any other queries just let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
