One feature I would really like to have is the ability to have the programmer time function assigned somewhere else (other than/in addition to) in the Z Menu.
I often require the desk to operate in a busking set up, it would however be useful to be able to toggle the programmer time on and off when changing gobo palettes and then also adjusting the programmer time value for quick adjustments to attribute changes such as colour.
I understand it isn't a massive amount of effort to jump into the Z menu however when using the internal touch screen for the groups page i would rather have quick access to both simultaneously.
Thanks
Joe
Hi Joe,
Programmer Time can be assigned to any empty Playback fader. Rather than having to tap Z and use an encoder, you can then simply use the fader to control the time, and use the playback button to toggle it on or off. Instructions on how to do this can be found here...
http://support.zero88.com/1011402011
Hope this helps, any queries let me know.
