Mirko Posted January 6, 2019 Report Posted January 6, 2019 Hello, i have been trying for days to insert my programmed chases from the playback faders into the master playback. As soon as I press play, nothing happens. I use the Zero 88 FLX S48 512! Can you help me? Quote
Edward Z88 Posted January 6, 2019 Report Posted January 6, 2019 Hello, Have you added Playback trigger macros into the cues you would like your chases to start in? To do this tap the Settings button for the cue in the Master Playback that you would like the chase to be triggered by. Then tap Macros... -> Add Trigger -> choose your chase playback. OK the Macros window, and OK the Cue Settings window. You should then find when you tap the Go button of your Master Playback to go into this trigger cue, the cue runs and the chase starts too. If you are finding that the chase triggers, but doesn’t run, you’ll need to check the chase playback’s BPM. This can be set manually using the chase playback’s button, or you can define a BPM by entering the chase’s settings. This is done by holding SETUP and tapping the chase’s button, where you can then type a defined BPM. If you’re still having issues, feel free to send a copy of your show file to support@zero88.com, along with a description of the issue, and one of the team will be able to help you. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
