thierry Posted December 19, 2018 Report Share Posted December 19, 2018 Hi everybody, is it possible to patch a fixture as an on/off switch, because i can't specify that i want an on/off circuit in my power rack ? Quote Link to comment Share on other sites More sharing options...
kgallen Posted December 19, 2018 Report Share Posted December 19, 2018 I don't believe so - would be interested to hear if it's possible - and if not I would like to see an enhancement request for ZerOS. (I believe consoles from the "other" major desk supplier supports the definition of a dimmer curve on the desk - an on/off switch at a user defined DMX/% threshold would be the simplest form of this). Quote Link to comment Share on other sites More sharing options...
thierry Posted December 19, 2018 Author Report Share Posted December 19, 2018 Ok, i've plugged the device i needed to an adb rack where i can set up the dimmer to on/off... But i've tried something before with my old solution28 power rack : patched my fixture as a dimmer , then recorded this fixture as a cue in a submaster, then i told that submaster to have the trigger release level at 100% (raise & lower menu)... it seems to do the job without damaging the fixture... Quote Link to comment Share on other sites More sharing options...
thierry Posted December 19, 2018 Author Report Share Posted December 19, 2018 Of course i think that it's better to set up correctly the desk & the power rack when we need a direct "on/off". i have my first 28 circuits plugged on a old Solution28 rack, an all the rest on ADB racks, so working with the SolutionXL is not a problem because ADB racks support the option of managing dimmers (curves, on/off...). But my "past" ADB Cantor desk used to do the job as well, but my "new" SolutionXL not, so if i need an on/off patched from 1 to 28, i can't have it unless i do what i explained before... Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 19, 2018 Report Share Posted December 19, 2018 Hi Both, I will ensure this feature request is logged. Currently the best way to switch a relay is patch a relay into your console, dial it’s Beamshape parameter to full, and then record to a playback. You can then configure the playback trigger level you would like your relay to switch on at in the playback settings. (On FLX you can use a UDK set to latch) Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
