Edit wheel groups for FLXs
rowanpaul
Hi Paul,
Your easiest option to customise the order the parameters are displayed on the encoders, is to list the parameters in order in the Fixture Editor “Parameters” tab.
Therefore delete the fixture groups, and reorder the parameters. To move a parameter to the end of the attribute, change the parameter to a different attribute and then back again.
Hope this helps,
  • 1 month later...
Hi Edward,
Since struggling to re-order parameters on a large fixture file before reading this hint, is there any chance that the 'parameters' column could be a user editable cell?
This would seems slightly more intuitive then the current method in my mind - and especially for new users to the software..!
Just a thought,
Cheers,
Alex
Hi Alex,
There aren’t currently any plans to update the Fixture Editor, however this is something we can bear in mind. A better solution may be to have up/ down arrows at the end of each parameter row, which you could use to reorder the parameters within their attribute.
