rowanpaul Posted December 10, 2018 Report Share Posted December 10, 2018 How do you edit a fixtures Wheel groups so they will appear on the encoder wheels when say beamshape is selected on an FLX screen. I get strobe and reset as my first 2 rather than Gobo6 Gobo8? Thanks Paul Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 10, 2018 Report Share Posted December 10, 2018 Hi Paul, Your easiest option to customise the order the parameters are displayed on the encoders, is to list the parameters in order in the Fixture Editor “Parameters” tab. Therefore delete the fixture groups, and reorder the parameters. To move a parameter to the end of the attribute, change the parameter to a different attribute and then back again. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
rowanpaul Posted December 11, 2018 Author Report Share Posted December 11, 2018 Thanks Edward, this was enough to get my main attributes on one page. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 11, 2018 Report Share Posted December 11, 2018 Hi Paul, No problem glad to hear it. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
scottydog75 Posted January 23, 2019 Report Share Posted January 23, 2019 On 12/10/2018 at 10:13 PM, Edward- Z88 said: To move a parameter to the end of the attribute, change the parameter to a different attribute and then back again. Hi Edward, Since struggling to re-order parameters on a large fixture file before reading this hint, is there any chance that the 'parameters' column could be a user editable cell? This would seems slightly more intuitive then the current method in my mind - and especially for new users to the software..! Just a thought, Cheers, Alex Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 23, 2019 Report Share Posted January 23, 2019 Hi Alex, 32 minutes ago, scottydog75 said: Since struggling to re-order parameters on a large fixture file before reading this hint, is there any chance that the 'parameters' column could be a user editable cell? There aren’t currently any plans to update the Fixture Editor, however this is something we can bear in mind. A better solution may be to have up/ down arrows at the end of each parameter row, which you could use to reorder the parameters within their attribute. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
scottydog75 Posted January 23, 2019 Report Share Posted January 23, 2019 1 hour ago, Edward- Z88 said: A better solution may be to have up/ down arrows at the end of each parameter row, which you could use to reorder the parameters within their attribute. Yes, this sounds perfect! If only it was so simple to implement haha. Cheers, Alex Quote Link to comment Share on other sites More sharing options...
