pierotec Posted December 10, 2018 Report Posted December 10, 2018 Hi, how can I configure the percentage display on the encoder wheels Thank you Quote
Edward Z88 Posted December 10, 2018 Report Posted December 10, 2018 Hello, Encoder wheels can only display raw DMX values, not percentages, in order to show you full control. You can however define a percentage for a parameter using syntax. To do this hold Z/SHIFT and tap a parameter name on the touchscreen above the encoder wheel, then tap Z/SHIFT, and use the syntax to type @, define your percentage, and then press ENTER. (If you are using an external USB keyboard you don't need to tap Z/SHIFT to show the syntax pad, you can simply type your percentage using the keyboard). Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
pierotec Posted December 10, 2018 Author Report Posted December 10, 2018 It does not seem to me that it works. I will try again but it is not very comfortable however on the old zerOs on Frog2 the type of visualization was settable Thanks for your answers Edward Quote
Edward Z88 Posted December 10, 2018 Report Posted December 10, 2018 Hello, No problem. It is actually a feature originally from FROG2. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
pierotec Posted December 22, 2018 Author Report Posted December 22, 2018 I believe reality it is easier to display a position or color parameter etc. in percentage, instead of example 65,500 Quote
Edward Z88 Posted December 22, 2018 Report Posted December 22, 2018 Hello, Our main thinking is that if you are moving a fixture, you’re going to be looking at the stage, not the encoders. Therefore it is more beneficial to have the exact raw DMX value on the wheel for finest control so you can see what you’re sending. For a visual representation of colour and position, you have the picker and the grid you can view. In a future update however, parameters such as position will actually display degrees, which is a much more useful value. All the best, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted December 22, 2018 Report Posted December 22, 2018 This is a constant topic of discussion. I don’t think either work well for position and colours should really have a palette name. Percentage only really works for intensity - for other parameters that have DMX ranges, percentage doesn’t really work as you lose 2.56x the precision and because of this a given percentage could be ambiguous on DMX range boundaries. Also fixture data sheets give the actual DMX value - the odd one I’ve seen that gives colour etc in percentage is a pain because this is not how the electronics decodes an 8-bit binary number, and the percentage rarely lines up correctly with the actual decoded binary value. Quote
pierotec Posted December 25, 2018 Author Report Posted December 25, 2018 ok, it’s right. I noticed that in the program window of the external screen the values are in percentage so I'm fine too, I would have preferred to the contrary, program window dmx e wheels percentage. 😉 Thank you P. Quote
