pause botton?
pierotec
To configure a playback button's function, hold SETUP and tap a playback's button to enter its settings. When in the playback settings there is a line of options to customise the button function. By default, a cue stack will have a normal button function of Go, however if you hold SHIFT and tap the button it will Go but ignore fade times, referred to as "Go (Snap)". You can therefore change the shifted button function to "Pause" if you wish. To do this hold Z/SHIFT, and choose "Pause" from the button options, and then release Z/SHIFT. Click OK on the settings window, and now when you hold SHIFT and tap the playback's button it will act as a pause.
Hope this helps, any queries let me know.
