Peter6442peter Posted December 2, 2018 Report Posted December 2, 2018 Hi I have 4 Robe colorspot 250at along front of stage. I have on playback 1 a chase each fixture following on from the other 1234. On playback 2 I have another chase this time the four split in 2 pairs 12.but when I put playback 1 up and it starts running OK. Then I put playback 2 up which should be different to playback 1, it mirrors playback 1 and then I can't get playback 2 back although when you view the playback on the screen it's showing the 2 steps. Hope that makes sense. Tech tomorrow evening Quote
Edward Z88 Posted December 3, 2018 Report Posted December 3, 2018 Hi Peter, Is the issue present when mixing Playback 1 and 2, or does Playback 2 not seem to be working correctly at all? I would recommend emailing your show file to support@zero88.com, along with a description of the issue, and one of the team will be able to take a look and see what may be causing this. Any queries let me know. Edward Quote Edward Smith Product Specialist Email Support
Peter6442peter Posted December 3, 2018 Author Report Posted December 3, 2018 Sorted Ed it was a trigger problem. It works OK when release on down is enabled Quote
Edward Z88 Posted December 3, 2018 Report Posted December 3, 2018 Hi Peter, Great glad to hear you’ve sorted it. If a playback has yet to be released, it cannot be “re-triggered”, hence it appeared to have stopped working. Edward Quote Edward Smith Product Specialist Email Support
