Gafferted Posted December 2, 2018 Report Posted December 2, 2018 Is there a quick way to untag/remove all parameters of a fixture from the programmer? Quote
Edward Z88 Posted December 3, 2018 Report Posted December 3, 2018 Hello, Your best option for this is to use Clear Fixture. If you hold SETUP and tap an empty UDK, you can choose “Clear Fixture” from either the normal or shifted drop down and then click OK. If you then wish to remove all programmer information for a fixture select it, and then press your Clear Fixture UDK. This is exactly like clearing the Programmer however for the currently selected fixture. If you wish to untag a Fixture rather than remove it from the programmer, select it, and then hold CLEAR and tap each attribute key twice, which should remove any tagged parameters. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support
