Hi George,
Kevin is correct. A palette will only contain one set of information for colour, beam or position. You would therefore create multiple palettes each with your moving head in a different position, that you could then use to record into a playback that you can then run through in sequence. You could turn this playback into a chase if you wish to run the positions automatically.
You may also want to take a look at the effects that are available, as these are a quick way to apply movement to your moving fixtures.
Hope this helps,
