ikopesorda
IOS app doesn't work
Hi ikopesorda,
The latest apps need ZerOS 7.9.4 or later to run successfully. I've updated the Promotional Text on the App Store to reflect this more clearly.
Apple allow you to reload an old version of an App by using iTunes. Please take a look at this link. Around half way down, there's a heading "What if the new version of the app is compatible with your device but, you still want to use the older version?" - hopefully this will be what you need. https://www.igeeksblog.com/how-to-re-install-older-version-of-apps-on-iphone-ipad/
Unfortunately you can't upgrade to 7.9.4 on  Frog2 hardware 😞 The last supported ZerOS for Frog2 is 7.8.2.39 (as you have).
http://support.zero88.com/Legacy-products/Legacy-Consoles/Legacy-ZerOS/975204871/FROG2.htm
This means you'll have to stick with an older ZerOS remote. Maybe Jon or Edward can help with which version and provide a pointer to that version...
Create an account
Register a new account
Sign in
