how do I copy playback cue to master playback?
From any cue, you can trigger any playback. Therefore in your master playback tap the Settings button for the cue you wish your chase to run in. In the cue settings tap Macros... -> Trigger Cue Stacks -> then tap the flashing playback button of your chase. Click OK on the macros window, and then click OK on the settings window. Now when you trigger this cue in the master playback it will run, and your chase will fade in too, using the fade time of your trigger cue. If you then wish the chase to stop in the next cue of the master playback, go into the settings of the next cue, tap Macros..., but this time choose Release cue stack, and again tap your chase's button to select it. When you trigger this cue, your chase will fade out using your cue fade times.
Hope that helps, if you have any queries let me know.
