On FLX S consoles, custom Defaults, Home and Max Level values cannot be configured. This is something that will be introduced in the software at a later date. In the meantime if you do wish to use this functionality there is a way round it. Save your show file from your FLX S, and load it into Phantom ZerOS software on PC running as a FLX console. You can then edit the Home, Default and Max Level values as required, re-save your show file, and then load it back into FLX S. The custom Home, Default and Max Level values will be loaded to.
Instructions on how to do this can be found here...
http://support.zero88.com/1011411491
Alignment configuration for Pan and Tilt inverting and swapping is available on FLX S, found as columns in the Fixture Schedule for your moving lights.
Hope this helps,
Configuring Home, Max Level and Default values is available in the latest beta version of ZerOS. If you would like access to this to gain a preview, please email support@zero88.com, and one of the team will be able to add you to the forum beta test group.
The date this software is to be released is yet to be confirmed.
Any queries let me know.
