jb07 Posted November 19, 2018 Report Share Posted November 19, 2018 Hello What is the lastest firmware ? on internet there are the 7.9.4 on my console I have :OS 7.8.1.2 and Software version 7.9.4.3 when is the new version ? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 19, 2018 Report Share Posted November 19, 2018 Hello, The latest public release software is ZerOS 7.9.4. New FLX S consoles are currently being manufactured with ZerOS 7.9.4.3, which allows for hardware compatibility. ZerOS 7.9.5 will be the next software version to be released. If you would like a preview of this software, please send us an email to support@zero88.com, requesting access to the beta version. Any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
jb07 Posted November 19, 2018 Author Report Share Posted November 19, 2018 I have send an email, what is new with this version ? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 20, 2018 Report Share Posted November 20, 2018 20 hours ago, jb07 said: I have send an email, what is new with this version ? Email sent Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
jb07 Posted November 23, 2018 Author Report Share Posted November 23, 2018 Hello I have try the update but it doesn't work I have download and unzip de zip file I have execute the exe file with a new uSB drive I have plug the usb in the usb port of the rear of the console I have swith ON the console The software stay is the 7;9;4.3 Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 23, 2018 Report Share Posted November 23, 2018 Hi jb07, Make sure you're following the instructions on the Release Notes. What you have described is not how you do a software update. You need to turn the console on without the USB stick, then plug it in, and go to SETUP > Load Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
jb07 Posted November 23, 2018 Author Report Share Posted November 23, 2018 I have fallow the instruction of the software cf picture If I go to load; I have no file on the USB drive If I see the usb drive on a computer; I have a directory "install" and a file "6q_bootscript" Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 23, 2018 Report Share Posted November 23, 2018 Hello, Running this software on PC is only required if your console is running ZerOS 7.8.3 or later. As you are currently running ZerOS 7.9.4.3, simply download the software from our website and, extract/unzip it to the root of a USB stick. Then plug into your FLX S, tap SETUP -> Load File, and choose the ZerOS .exe file. The console will run the software update, and when complete ask to you to turn the console off. The next time you switch the console back on the latest software will be installed, and the console will be completely factory reset. Hope that helps, any queries let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
jb07 Posted November 23, 2018 Author Report Share Posted November 23, 2018 Hello I have copied the file "phantomZerOS 7.9.4.19 MD beta.exe" on the root of the USB stick setup; load file; select "phantomZerOS 7.9.4.19 MD beta.exe"; 2 advertissments and upgrade failled; File does not contain an upgrade package Thanks Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 23, 2018 Report Share Posted November 23, 2018 Hello, That file is for Phantom ZerOS, which is software that runs on PC to emulate FLX S. Along with this file you should find ZerOS 7.9.4, the software file for FLX S. This should start downloading using the link below... https://zero88.com/forum/files/file/17-zeros-794/?do=download&r=752&confirm=1&t=1&csrfKey=cb99a9f94e13c9e27c587fd2b247778e If you have any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
jb07 Posted November 26, 2018 Author Report Share Posted November 26, 2018 hellom the link is bad : Error code: 2S119/1 Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 27, 2018 Report Share Posted November 27, 2018 Hi jb07. You should see a "Downloads" tab at the top of the forum. This should get you here (you might have to scroll to the next page by clicking the >). It should get you here: Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 27, 2018 Report Share Posted November 27, 2018 Hi jb07, Not sure why that didn't work. Use Kevin's link above! Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
jb07 Posted December 8, 2018 Author Report Share Posted December 8, 2018 Hello I wanted to retry to update but impossiblem I do not understand. I downloaded the file PhantomZeroOS 7.9.4.23; I unzip on a blank usb stick the exe file I put the usb sitck on the console; setup and load the exe file; after the 2 warnings; I have an error : looking for upgrade package; file does not contain an Upgrade package; upgrade fail thanks Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 9, 2018 Report Share Posted December 9, 2018 Hello, DO NOT load "PhantomZerOS 7.9.4.23 MD Beta.exe" into FLX S. This is to be ran on PC NOT consoles. Contained in the same link should be a file named "ZerOS OS Creator USB - v7.9.4.23 7-12-2018 MD Beta.exe". This is the console operating system for you to load in. (ZerOS 7.9.4.23 is beta software) Any queries just let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
jb07 Posted December 9, 2018 Author Report Share Posted December 9, 2018 ok I succeeded (finally) Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 9, 2018 Report Share Posted December 9, 2018 Hello, Fantastic glad to hear it. If you have any further questions just let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
