Harry Kerver Posted November 16, 2018 Report Posted November 16, 2018 Hello, Yesterday I've updated the latest ZeroOs software for the Orb desk. When I want to program a submaster, it shows the playback directory. According the old manual I have to: Hold SETUP and press the select key above a playback etc. but that doesn't seem to work. I could use some help on this one? Regards, Harry Kerver Quote
Edward Z88 Posted November 16, 2018 Report Posted November 16, 2018 Hi Harry, To program a submaster (which in the new software is referred to as a playback containing a single cue), create your lighting state, tap RECORD, and then tap the playback button to store to. SHIFT + FADER FUNCT will open your Faders Window to show you what they're currently doing. SHIFT + SUB will open your Playback directory. It is worth mentioning the SUB and STACK keys in the latest software both have identical functionality. Holding SETUP + tapping a playback's button will enter the playback's settings. You may find the document below useful, which goes through the software changes... http://support.zero88.com/988876801 Hope that helps, if you have any queries just let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Mihail Sabevski Posted December 31, 2018 Report Posted December 31, 2018 Hi Edward, Thank you very much for the prompt reply and for the support. I wish you a very pleasant, healthy and fruitful New Year! We will be hearing after a New Year if I have new questions. Regards, Mihail Sabevski Quote
