sp Posted April 19, 2004 Report Share Posted April 19, 2004 Hi, just a little suggestion... On other desks I use is a latch feature for the submaster flash buttons, which I find quite useful. Could this be implemented easily in a future update? So when you cycle through the flash button options it could be: 1. Flash buttons off (No LED) 2. Flash (Flash LED on) 3. Solo (Solo LED on) 4. Flash latch (Flash LED blinking) 5. Solo latch (Solo LED blinking) cheers, sp Quote Link to comment Share on other sites More sharing options...
Haytech Posted April 20, 2004 Report Share Posted April 20, 2004 Hi, what about a SOLO disable ? I think MA has a similar function on lightcommander could be done in desk setup: SOLO on chan LED is on SOLO off: chan LED is off - This function should only used by HTP channels. Should be the same thing... Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone Link to comment Share on other sites More sharing options...
