Maybe a stupid question, I'm pretty new using the Orb.
Our table has just been programmed withe the latest fixtures and addresses.
Do I have to re-programme the table when I do the latest software update?
Could use some help here.
You should be able to save your setup, just as per a show, to USB stick. Then update the ZerOS desk software, then reload your show from the USB stick.
If you have your own fixture definitions (ones you created yourself) then you will need to reload these. Probably best to do this before reloading your show above. The showfile will carry with it all the fixture defintions required, but when you go to the next show you won't have the others that maybe weren't used in the particular setup you had at the start.
Hope that makes sense and I understood your question correctly!
