jb07 Posted November 10, 2018 Report Posted November 10, 2018 Why it is not possible to delete one (or more) CUE in a program (chase) ? On all my other consoles you could delete a step or make a copy/paste etc... or it is possible to export a chase for editing on a computer ? Quote
kgallen Posted November 10, 2018 Report Posted November 10, 2018 It is. But the way to do it on FLX S is slightly different to the main FLX because FLX S doesn't have all physical buttons. It was covered very recently, have a look back a couple of months i the FLX S forum. I'll look too... Something like this: Also, have you read the manual is this respect...? https://zero88.com/manuals/FLX S User Manual v1.pdf Quote
jb07 Posted November 11, 2018 Author Report Posted November 11, 2018 hello thanks for the answer I have read de french manual but It's not always obvious to understand everything, sometimes I have to look in the original manual. For the other question, it is possible to export a chase for editing on a computer ? Quote
Edward Z88 Posted November 11, 2018 Report Posted November 11, 2018 Hello, To delete multiple cues from a playback, tap DELETE -> Z/Shift -> type the cue number you wish to get rid of. This numpad has Thru and And buttons, which can be used to delete a range or multiple cues. Tap the Playback’s flashing button to complete the command. You can save your show file to USB, which you can then load into PhantomZerOS. PhantomZerOS can be downloaded for free from our website which will emulate FLX S. You can then edit your chase, save your show, and load it back into FLX S using USB. Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
jb07 Posted November 11, 2018 Author Report Posted November 11, 2018 Thank you for the answers I just tried it works well. I am a beginner on this console I learn every day Quote
Gingersteve91 Posted November 23, 2021 Report Posted November 23, 2021 Hi All, Just came to ask the same question, glad I'm not the only one! I come from an OrbXF/Full FLX background where I'm so used to doing everything on the syntax line via button crunching. The lack of buttons on the FLX S is catching me out. I found the alternatives for most things, just couldn't see how to delete a single cue... Dam I felt so dumb. Thanks for clearing this up. Steve. Quote
