Why it is not possible to delete one (or more) CUE in a program (chase) ?
On all my other consoles you could delete a step or make a copy/paste etc...
or it is possible to export a chase for editing on a computer ?
hello thanks for the answer
I have read de french manual but It's not always obvious to understand everything, sometimes I have to look in the original manual.
For the other question, it is possible to export a chase for editing on a computer ?
To delete multiple cues from a playback, tap DELETE -> Z/Shift -> type the cue number you wish to get rid of. This numpad has Thru and And buttons, which can be used to delete a range or multiple cues. Tap the Playback’s flashing button to complete the command.
You can save your show file to USB, which you can then load into PhantomZerOS. PhantomZerOS can be downloaded for free from our website which will emulate FLX S. You can then edit your chase, save your show, and load it back into FLX S using USB.
Hope that helps,
Product Specialist
Email Support
  • 3 years later...
Hi All,
Just came to ask the same question, glad I'm not the only one!
I come from an OrbXF/Full FLX background where I'm so used to doing everything on the syntax line via button crunching. The lack of buttons on the FLX S is catching me out.
I found the alternatives for most things, just couldn't see how to delete a single cue... Dam I felt so dumb.
Thanks for clearing this up. Steve.
