Mantrix Posted November 9, 2018 Report Share Posted November 9, 2018 I got a flx s24 and there is a event comming. so my question is. is there a way that i just press the play butten and the light will just play a chase that i made. But I only want to press play and the there are alot of breaks in the event songs. like A song is starting. i select a profile and in the profile there are configuration when the lights change color or go off and on. And is there a way make a virtual system from my place where the lights are so i can prepare at home. The light control is at the event and i cant take it home. and I want to save the profiles in a portable ssd Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 10, 2018 Report Share Posted November 10, 2018 Page 18 for Chase playbacks: https://zero88.com/manuals/FLX S User Manual v1.pdf PhantomZerOS: Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 11, 2018 Report Share Posted November 11, 2018 Hello, After programming your chase onto a playback, enter the chase’s settings by holding SETUP + tap it’s button, and then choose General -> Button Function -> Go. The playback button will then act as a play button for the chase. SHIFT + GO by default will be GO Snap, meaning you can snap into a chase cue. As Kevin has linked to, PhantomZerOS is free to download from our website, which allows you to emulate FLX S24 on PC. You can edit and create show files, save them on PC, which you can then load into your actual console. Hope that helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mantrix Posted November 19, 2018 Author Report Share Posted November 19, 2018 Thank you guys for the reply I still have one question. Is there a virtual program where i can build a stage with the lights and use PhantomzerOS? Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 19, 2018 Report Share Posted November 19, 2018 Not unless you pay out ~400Eur/GBP and buy Capture 😞 Quote Link to comment Share on other sites More sharing options...
