I got a flx s24 and there is a event comming. so my question is.
is there a way that i just press the play butten and the light will just play a chase that i made. But I only want to press play and the there are alot of breaks in the event songs.
like A song is starting. i select a profile and in the profile there are configuration when the lights change color or go off and on.
And is there a way make a virtual system  from my place where the lights are so i can prepare at home. The light control is at the event and i cant take it home.
and I want to save the profiles in a portable ssd
After programming your chase onto a playback, enter the chase’s settings by holding SETUP + tap it’s button, and then choose General -> Button Function -> Go. The playback button will then act as a play button for the chase. SHIFT + GO by default will be GO Snap, meaning you can snap into a chase cue.
As Kevin has linked to, PhantomZerOS is free to download from our website, which allows you to emulate FLX S24 on PC. You can edit and create show files, save them on PC, which you can then load into your actual console.
Hope that helps,
Product Specialist
Email Support
  • 2 weeks later...
