RaffaABC Posted November 5, 2018 Report Posted November 5, 2018 I just got my FLX S48. I have 12 of this, but the model does not apear on my desk list? What do I do...?? https://www.amazon.com/dp/B01COB6KZQ/ref=dp_cerb_2 Quote
Edward Z88 Posted November 6, 2018 Report Posted November 6, 2018 Hello, Please send an email to FixtureSupport@zero88.com, along with a copy of the fixture's manual, and one of the team will be able to make a fixture file for you. You will then be able to copy this to USB, plug into your FLX S48, and load it in. You'll then be able to patch the fixture in the usual way. Any queries let me know, Edward Quote Edward Smith Product Specialist Email Support
RaffaABC Posted November 6, 2018 Author Report Posted November 6, 2018 Ok.. Already send the e-mail Hope it doesn't take that long... https://www.monoprice.com/product?p_id=612751 https://www.monoprice.com/product?p_id=612788 Quote
kgallen Posted November 6, 2018 Report Posted November 6, 2018 3 minutes ago, RaffaABC said: Hope it doesn't take that long... If you're in a big hurry, use the Fixture Tools provided by Zero88 to write your own fixture definition. See here, there are instructions too: Quote
RaffaABC Posted November 6, 2018 Author Report Posted November 6, 2018 SO... do I install this in to my computer? Quote
RaffaABC Posted November 6, 2018 Author Report Posted November 6, 2018 Dammm.... That's to PRO for me...I leave it to the XPERTS Quote
kgallen Posted November 6, 2018 Report Posted November 6, 2018 Oh come on! You've got a pretty basic fixture: R,G,B,W,A,UV colours, a dimmer and a strobe. Here's one I made for a similar fixture, it's probably pretty close to the one you've got, so probably not that much to change! Use the "Performer 18 Quad : 8 channel mode" as a starting point... LEDJ_P18Q_S7Q5_S9Q8.ift Quote
kgallen Posted November 6, 2018 Report Posted November 6, 2018 40 minutes ago, RaffaABC said: SO... do I install this in to my computer? Yes, install on a Windoze PC... Quote
RaffaABC Posted November 7, 2018 Author Report Posted November 7, 2018 Thank you I aprecciate mate !! Quote
RaffaABC Posted November 12, 2018 Author Report Posted November 12, 2018 Does any body knows how to BLACK OUT all? Quote
Edward Z88 Posted November 12, 2018 Report Posted November 12, 2018 Hello, On FLX S, any of the Playbacks be customised to become a Grand Master. Doing so turns the playback's button into a Blackout button for the console. To do this, hold SETUP and tap any empty playback's button. From this menu that opens, you can choose Grand Master, and click OK. This playback's button will then be the console's Blackout button. This can then be customised to flash rather than latch if you wish. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support
jb07 Posted November 12, 2018 Report Posted November 12, 2018 hello Press and hold the key "setup" and press the key "master playback" (triangle play) Select "GRAND MASTER" for the fader function and latch for the button function Quote
RaffaABC Posted November 12, 2018 Author Report Posted November 12, 2018 Great.. Thank you so much Quote
