AlexTec Posted October 23, 2018 Report Share Posted October 23, 2018 Hello. I have new FLX S 48 512. Fixtures from library reissued, working except 6 Cameo LEDStudioPar64. Software 7.9.4. 6Ch-Mode, 9Ch-Mode tried - all colors flakern (like Strobo). Cable plugged into a MA console - no more flickering. Where is the problem ? Thank you Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 23, 2018 Report Share Posted October 23, 2018 Hello, From your description, it sounds as if these fixtures are not receiving RDM information correctly. FLX S consoles have software running in the background called RigSync, which allows for a 2-way communication between FLX S and your lighting rig, keeping the two synchronised. You can read a little more about this on our website here... http://support.zero88.com/995963301 Some fixtures mistake this RDM data for DMX if they have poor implementation. Therefore to resolve this issue, simply tap SETUP -> Inputs & Outputs -> RigSync -> Disabled. RDM traffic will then stop, which you will probably find stops the fixtures flickering. If you have any queries let me know, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexTec Posted October 25, 2018 Author Report Share Posted October 25, 2018 Thank you Quote Link to comment Share on other sites More sharing options...
AlexTec Posted October 26, 2018 Author Report Share Posted October 26, 2018 I disabled RigSync and that solved the problem pretty much. Thank you for helping out. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 26, 2018 Report Share Posted October 26, 2018 Hello, Great glad to hear that solved your issue. If you have any further queries just let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexTec Posted November 4, 2018 Author Report Share Posted November 4, 2018 Hello Edward. I have a problem with the "Stairville B5R" fixture. The device is present in the library, but the gobo icons are not displayed. The parameters are absolutely the same as "Clay Paky Sharpy". I re-created the Sharpy, gobos are shown. How can I apply the Sharpy icons for B5R so that the gobo image does not disappear? Is there a trick? Kind regards, Alextec (Translated by google translator) Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 6, 2018 Report Share Posted November 6, 2018 Hi Alex, Gobo images are stored in the fixture personality. Therefore this will need to be edited to implement the images. This is something you can do yourself if you wish, using our Fixture Tools software available to download here... https://zero88.com/forum/files/file/10-fixture-tools/ Alternatively, send a request to FixtureSupport@zero88.com along with the fixture's manual, and one of the team will be able to add these images and send you a new version of the fixture file. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexTec Posted November 8, 2018 Author Report Share Posted November 8, 2018 Thanks for your reply Edward. I'll try it via "FixtureSupport". Kind regards, Alex Quote Link to comment Share on other sites More sharing options...
