nbaldwin Posted October 23, 2018 Report Posted October 23, 2018 Is the MFK sub-board compatible with both the Leapfrog 98 and 48? We have one fairly tired LF96 console that has a few sticky MFKs but we also have a fairly under-used LF48. I tried swapping the MFK sub board from the 48 to the 96 but while the keys themselves seemed to work, the display above them was blank. The two consoles are running different OS/firmware (the 48 has an older firmware, the 96 has the latest Beta) - could it just be a matter of updating the 48 and *then* swapping the MFK board? Thanks, Neil Quote
Edward Z88 Posted October 23, 2018 Report Posted October 23, 2018 Hi Neil, I would recommend dropping us an email to support@zero88.com, where Keith will be able to talk you through it. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
iank99 Posted October 27, 2018 Report Posted October 27, 2018 Looking at the Schematic's for this PCB - there's a DIP switch on there that probably sets an "ID" for each PCB once it's in the desk - multiple boards will need a unique ID setting. Check that the board you put in has the same DIP switch settings as the board you removed... There's no processor as such on the PCB so there's no firmware to update - the ZerOS updates affect the processor board itself so doing an update won't cure the issue. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
nbaldwin Posted October 29, 2018 Author Report Posted October 29, 2018 On 10/23/2018 at 6:02 PM, Edward- Z88 said: Hi Neil, I would recommend dropping us an email to support@zero88.com, where Keith will be able to talk you through it. Edward Done that. Thanks Edward. Quote
nbaldwin Posted October 30, 2018 Author Report Posted October 30, 2018 Sorted it with Keith's help. :) Quote
Edward Z88 Posted October 30, 2018 Report Posted October 30, 2018 Hi Neil, Great, glad to hear it. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
