Grand Master does not work at startup
Tapani
Since the update to 7.9.4 the Grand Master does not work at startup.
If the active lighting moods or channels are set to 0 via the Grand Master before switching off and the FLX is switched off afterwards, the previously active tunes / channels will be restarted at the start with the original values, even though the Grand Master is at position 0. In order to get the Grand Master function back on the fader, you have to move it up and down first.
That's correct. The behaviour of the Grand Master changed in ZerOS 7.9.3, so that now on boot the Grand Master level will be at full, irrespective of fader level. This allows you to then grab control, by level matching the Grand Master fader. This allows for any Playback fader to be configured as a Grand Master, and also means that if you're not someone who ever uses a Grand Master, you don't need to touch it. It also means that if you were in a lighting state, turn the console off, when you reboot FLX will recover the lighting state, even if the Grand Master has been adjusted since.
If you have any queries please let me know.
Product Specialist
Email Support
