Mars Posted April 19, 2004 Report Posted April 19, 2004 Having a tech-guest per performance (our shows run only once), one of them was searching on the desk for this feature: While using the (preset-)faders, to increase automatically the scenenumber when the fader drops below 5% and loads the next scene. fader A 100%: scene 37 ; fader B 0% scene 38 faders both down, fader A loads scene 39 when below 5% fader A 0%: scene 39 ; fader B 100% scene 38 faders both up, fader B loads scene 40 when below 5% &c, &c. He: "It is on a Spark, and should be on the new zero-desks by now." My reply: "I buy 3 frogs for that price, but I've no sponsor." He did the show from the subs. Also, some discussion about the paging began: why restarting the subs-numbers from 1 to 12 on page 2 (& onwards) instead of carry on with 13 to 24 on page 2, 25 to 36 on page 3, &c, &c (needs a 3 digit display up to 240, preferred over F0h). I taped it for him, and peeled the layer off when moving to the next page. That could be a software feature. 8) Quote
NZ Posted April 20, 2004 Report Posted April 20, 2004 Hi What you are asking for in terms of an A/B cross fade on memories is something that exists on the Illusion. We didn't see this as a feature that many people would want on the Frogs. Maybe I am wrong but this is the first time in nearly 3 years it has been asked for. We will look at it but no promises as I think it would be a major thing to do. On the next generation it is more likely. :wink: Quote Graham
K-Nine Posted April 20, 2004 Report Posted April 20, 2004 Certainly, on the Frogs this would be a MAJOR new function to design and implement ! On a more historical note there was a major debate on whether it should be included on the original Illusion desks as well 8O Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Mars Posted April 20, 2004 Author Report Posted April 20, 2004 Thanks for the response. It is understandable that the A/B cross fade on memories is not a current issue for the Frog range. But how about the subs counting. A SU option? If not, tape will work also. Quote
