Uriahdemon Posted September 30, 2018 Report Posted September 30, 2018 Hi, I am having quite a bit of trouble trying to get my iPAD running ZerOS Remote to connect to my FLX desk. That is not entirely surprising as I am not too sharp when it comes to networking setups. I was wondering if anyone has or can point in the way of some basic advice on how to do this. I have 'Remote' enabled etc but still no joy at all. I am guessing it is to do with IP addressing but not too sure where to start with it all. Quote
kgallen Posted September 30, 2018 Report Posted September 30, 2018 Maybe you've been pointed to this page already, if not, maybe this helps? http://support.zero88.com/Legacy-products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/996119181/How-to-connect-apps-to-ZerOS-iOS.htm Quote
Uriahdemon Posted October 1, 2018 Author Report Posted October 1, 2018 16 hours ago, kgallen said: Maybe you've been pointed to this page already, if not, maybe this helps? http://support.zero88.com/Legacy-products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/996119181/How-to-connect-apps-to-ZerOS-iOS.htm Thanks Kevin, much appreciated. On reading this I am pretty sure I have covered off all the recommendations but I still cannot get the FLX to connect to the router. I have the FLX set up to run CAPTURE, would anything done there affect connection to the router. Also if and when I manage to set up the router would any of that set up config affect what I have in place for CAPTURE. Slightly off topic I know none the less important. PS... I have tried 3 different cables Quote
kgallen Posted October 1, 2018 Report Posted October 1, 2018 Sorry, I don't know. However I will be interested in the answer from Edward as I might end up investing in CAPTURE soon too... Sorry I can't help any more! Quote
Uriahdemon Posted October 1, 2018 Author Report Posted October 1, 2018 2 hours ago, kgallen said: Sorry, I don't know. However I will be interested in the answer from Edward as I might end up investing in CAPTURE soon too... Sorry I can't help any more! thanks anyway. Quote
Edward Z88 Posted October 1, 2018 Report Posted October 1, 2018 Hi Mac, Hope you're well. So I'm guessing your network setup is FLX plugged into one Ethernet port of your wireless router, and your PC plugged into another running Capture? On FLX is Capture set to use a static IP address? Is the Remote on FLX set to DHCP? If so you can confirm the status of these settings outside of Setup, by tapping Z -> System Information -> Network Overview. At the top you should see a line of text displaying "DHCP address", and then list the IP you have been assigned. Can you confirm this is in the same range as your iPad, and that it is reporting no errors? You can find out your iPad's IP address in iOS by tapping the Settings app -> WiFi -> Tap your router's network. Your IP and subnet will be listed. In a simple network like this, as long as the first 3 values of the IP address are the same, and the last value is different on all devices connected, you should be fine. After changing configurations such as changing IP addresses or swapping out Ethernet cabling, make sure you disable and re-enable the remote connection, otherwise you may experience a socket error. If you have any queries as always just let me know, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted October 1, 2018 Author Report Posted October 1, 2018 2 hours ago, Edward- Z88 said: Hi Mac, Hope you're well. So I'm guessing your network setup is FLX plugged into one Ethernet port of your wireless router, and your PC plugged into another running Capture? On FLX is Capture set to use a static IP address? Is the Remote on FLX set to DHCP? If so you can confirm the status of these settings outside of Setup, by tapping Z -> System Information -> Network Overview. At the top you should see a line of text displaying "DHCP address", and then list the IP you have been assigned. Can you confirm this is in the same range as your iPad, and that it is reporting no errors? You can find out your iPad's IP address in iOS by tapping the Settings app -> WiFi -> Tap your router's network. Your IP and subnet will be listed. In a simple network like this, as long as the first 3 values of the IP address are the same, and the last value is different on all devices connected, you should be fine. After changing configurations such as changing IP addresses or swapping out Ethernet cabling, make sure you disable and re-enable the remote connection, otherwise you may experience a socket error. If you have any queries as always just let me know, Edward Hi Ed, I am well, hopefully the same with you. OK, I am giving this another go this evening and to start with I made a fatal (numpty) mistake. I had actually plugged the ethernet cable into the internet port in the router. I plugged it into one of the ethernet ports and I now have ZerOS Remote talking to the desk. I did not try Capture at the same time last night but have now configured it as you state above i.e. 'FLX plugged into one Ethernet port of your wireless router, and your PC plugged into another running Capture'. The trouble I have now is that the desk is not talking to Capture. I used a direct connection from the desk to my laptop previously and all worked fine but unfortunately not now. The Network Overview info is as following: DHCP - IP Address - 192.168.0.102 Capture - Transmitting on - 192.168.0.102 Remote - Listening on - 192.168.0.102 - 1 connection active IPAD address when looking at the Router wifi link info - 192.168.0.101 Capture is Enabled and 'Use DHCP Address' is enabled. On FLX - Remote is Enabled as is DHCP Hopefully the end game with this set up is to be able to: When programming use Capture for visualisation so just the FLX console into the router and router connected to laptop. When in live scenario use ZerOS Remote connected to router and laptop running Phantom OS with unlock dongle as a back up just in case. Thanks again for your help, much appreciated. Mac Quote
Edward Z88 Posted October 2, 2018 Report Posted October 2, 2018 Hi Mac, 13 hours ago, Uriahdemon said: The Network Overview info is as following: DHCP - IP Address - 192.168.0.102 Capture - Transmitting on - 192.168.0.102 Remote - Listening on - 192.168.0.102 - 1 connection active Capture is Enabled and 'Use DHCP Address' is enabled. On FLX - Remote is Enabled as is DHCP As you have both Capture and Remote using DHCP it means these different protocols are on the same IP address. I would recommend setting Capture to 192.168.0.10 rather than DHCP. You should find your laptop will now listen to FLX. 13 hours ago, Uriahdemon said: When programming use Capture for visualisation so just the FLX console into the router and router connected to laptop. You will still be able to connect directly into your laptop if you don't wish to use the Remote. You may find you'll need to disable/re-enable Capture after unplugging network cabling. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted October 2, 2018 Author Report Posted October 2, 2018 9 hours ago, Edward- Z88 said: Hi Mac, As you have both Capture and Remote using DHCP it means these different protocols are on the same IP address. I would recommend setting Capture to 192.168.0.10 rather than DHCP. You should find your laptop will now listen to FLX. You will still be able to connect directly into your laptop if you don't wish to use the Remote. You may find you'll need to disable/re-enable Capture after unplugging network cabling. Any queries let me know. Edward Hi Ed, now working a treat, thanks very much for your help. Now for me to get an unlock dongle and set up the laptop as a tracking back up. Best Rgds Quote
Edward Z88 Posted October 2, 2018 Report Posted October 2, 2018 Hi Mac, Great, no problem at all. If you have any queries configuring Tracking Backup just let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
