Martin Oakley Posted September 27, 2018 Report Share Posted September 27, 2018 Hi, We have just purchased an FLX s48 and waiting for delivery. We soon will be purchasing a touch screen monitor which will require a USB connection. If I use a USB hub can I simply connect keyboard and mouse to this hub and connect to FLX s48 Quote Link to comment Share on other sites More sharing options...
kgallen Posted September 27, 2018 Report Share Posted September 27, 2018 On my FLX (not FLX S), I connect the touch screen to one (rear) USB port, then in the other (rear) USB port I have a 4-way Belkin unpowered hub with keyboard, mouse and sometimes USB stick (usually I use the USB port on the top of the FLX for the USB stick). Zero88 would recommend a powered hub, but if you're sensible with what you attach I think you're ok for an unpowered one in the keyboard/mouse application. Jon/Edward may disagree. It's possible the different USB ports can support different power requirements, but certainly on FLX I know Jon said they did lots of USB power load testing... Mileage may vary slightly on FLX S - I don't know how many USB ports are on the S24 or S48. Quote Link to comment Share on other sites More sharing options...
Martin Oakley Posted September 27, 2018 Author Report Share Posted September 27, 2018 Many thanks for this I shall get buying. Not directly related, but is there a 'recommended' touch screen monitor? I notice a couple of posts referring to iiyama. Quote Link to comment Share on other sites More sharing options...
kgallen Posted September 27, 2018 Report Share Posted September 27, 2018 1 hour ago, Martin Oakley said: is there a 'recommended' touch screen monitor? I notice a couple of posts referring to iiyama. See here: http://support.zero88.com/Legacy-products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/975056031/Compatible-touchscreen-monitors-with-ZerOS-consoles.htm I think I've got the Iiyama 1731SR-B which is the one that Zero88 use for their training and demos etc. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 27, 2018 Report Share Posted September 27, 2018 Hi Both, 3 hours ago, kgallen said: Zero88 would recommend a powered hub, but if you're sensible with what you attach I think you're ok for an unpowered one in the keyboard/mouse application. Jon/Edward may disagree. It's possible the different USB ports can support different power requirements, but certainly on FLX I know Jon said they did lots of USB power load testing... FLX has rugged power management, meaning if you try to draw too much current from a USB port it will be automatically switched off, rather than start to pull the voltage rail down. FLX S consoles however don't have this sort of management, so I would recommend routing through an active/powered USB hub before connecting more power-hungry USB devices. Any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
