use flx effects
B3n
If you have programmed an Effect to a playback, you can enable Fader Controls Effect on that playback. This is done in the playback settings by holding SETUP and tapping your effect playback, and choose "Effect" from the Fader Controls... buttons.
The Effect speed and size will then be scaled by the fader.
Product Specialist
Email Support
  • 1 month later...
Hi Glenn,
There is not a master effect rate control, however Speed Override will control the rate of your effects.
Speed Override is found on the second encoder wheel by tapping Z/Shift, and can be used to slow down or speed up the running effect on the currently viewed playback. Therefore to choose which playback you wish to control, hold VIEW and tap your playback's button. You can also configure Speed Override to be controlled by a fader as well as an encoder, by holding SETUP and choosing an empty playback button. You can then select Speed Override from the options.
Product Specialist
Email Support
