Nico6868 Posted September 13, 2018 Report Share Posted September 13, 2018 Hello, I would like to check if there is a way to delete a cue which is record in a playback on my flxs48 for example I created 10 cues in the master playback, and finally I want to delete cue #6... how can you do that? then if possible how is,it,going to,impact the others cues number? #7 will go to #6 or will remain number #7 and you have a hole in between #5 and #7? thanks for,your help best regards Quote Link to comment Share on other sites More sharing options...
kgallen Posted September 13, 2018 Report Share Posted September 13, 2018 Page 23 in the User Manual: https://zero88.com/manuals/FLX S User Manual v1.pdf "Deleting Cues To delete a cue, press the Delete button, press Ⓩ , and then type the cue number you wish to delete (for example 15 ), and then press the Playback button which contains the cue you wish to delete (for example, the Master Playback). To delete multiple cues, the “thru” button can be used (for example 15 Thru 20 ). To delete all cues within a playback, see “Deleting playbacks” on page 16. Deleting a cue cannot be undone." Cues are not renumbered, so yes, you will have a "hole" between cue 5 and cue 7. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 14, 2018 Report Share Posted September 14, 2018 Hi Nico, As Kevin points out, this is done by defining the cue number. You don't have to tap Ⓩ, if you have an external keyboard connected - you can simply tap DELETE [cue number], and tap your Master Playback button to complete the command. You can then confirm the delete. If you don't wish to have a gap in your cue stack, you can the renumber the whole playback, by holding SETUP and tapping your Master Playback's Go button, tap Advanced Renumber -> OK. Any queries let me know, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Nico6868 Posted September 14, 2018 Author Report Share Posted September 14, 2018 Thanks to both of you Quote Link to comment Share on other sites More sharing options...
jb07 Posted November 11, 2018 Report Share Posted November 11, 2018 I have try it's work thanks Quote Link to comment Share on other sites More sharing options...
