Dear All,
Zero 88 Fixture Library version 36 has now been released.
For full information, please visit: http://zero88.com/software/library
This release contains 8457 fixtures from 325 different manufacturers. For a list of fixtures in the library please click here.
The library is released in 2 formats:
  • Full version for desks running ZerOS software (ORB Series, Solution series, FLX Series, FROG2 and Leap Frog 48 & 96).
  • Filtered version for other Zero 88 desks. This removes data that is not used by these other desks, so that the file is smaller. When using a floppy disk (original Frog series, Illusion 500) it is recommended that the floppy disk be freshly formatted before using it.
Download & Installation
The correct format of the library for your desk can be downloaded by clicking the product name below.
The library (.ift file) should be placed in the root directory of the floppy disk or USB stick.
ZerOS desks (ORB Series, Solution series, FLX and Leap Frog 48 & 96)
To load this file into your console extract it to the root of a USB stick and plug into your console. Then tap SETUP, tap "Load File", then select the GFT.ift file.
FROG2
JesterML & JesterTL
The fixture library is installed on the desk at manufacture, however this can be updated from USB if required in Setup -> Update Fixture Lib -> Update Library.
Frog Series and Illusion 500
Use 'Common Fixture Manager' (included in the Fixture Tools download) to select the fixtures you wish to use, and save this as a file to a floppy disk.
Diablo
The fixture library is used with the Diablo Fixture Manager PC software.
Sirius 250/500
Use the Fixture Type Editor to import fixture types from the fixture library, and then use the ‘Export Sirius UFT’ function (under the ‘File’ menu) to generate data in the correct format for the Sirius 250/500.
Further details of assigning fixtures on the desk to fixture types in the fixture library can be found in each desk’s operating manual.
Additional Fixtures
If you need a fixture type which is not in the library, please read the following thread:
Jon Hole
