JR Light Posted August 13, 2018 Report Share Posted August 13, 2018 Hello, Is it possible to update a playback with more fixtures. For example: I have created a playback as colour fader only for 4 LED fixtures. Or a playback with an effect only for 4 LED fixtures. Now I have 8 LED fixtures. Is it possible to update the playback with the new number of fixtures without starting over again for the new number of fixtures? Best regards, Jeroen Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 14, 2018 Report Share Posted August 14, 2018 Hi Jeroen, If the new set of 4 fixtures are the same fixture type as the existing 4, any palettes you recorded with the original fixtures will also work for the new ones. Therefore you could select your new fixtures and apply the palette you used to record the playback. You can then simply Update the playback, which will then include the new fixtures. Hope that helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
JR Light Posted August 15, 2018 Author Report Share Posted August 15, 2018 Hello Edward, Thank you for your reply. It is working what you suggested but you have to remember which effect/color/beam/position pallets you had applied to create the playback initial. Mayby on the same evening I will remember but after a week I am lost. I hoped there was an easier way. Best regards, Jeroen Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 16, 2018 Report Share Posted August 16, 2018 Hi Jeroen, FLX S consoles don't have the ability to copy channel data. This is something the ORB series consoles can do... http://support.zero88.com/975363271 Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
