sabah69 Posted August 3, 2018 Report Posted August 3, 2018 Hi I have just updated a Leapfrog 48 however it fails to recognise USB sticks. If you restore desk to factory it will read the stick once but then fails to see it again. Have reformatted sticks and tried different ones, all which worked fine in previous firmware. Any help available? Thanks in advance. Quote
Jon Hole Posted August 3, 2018 Report Posted August 3, 2018 Hi sabah69, Strange. What make, model and size of USB stick are you using? Try doing a Factory Restore, save the empty showfile to the USB stick, unplug the USB stick, plug it back in, and then try loading that "empty" showfile back into the console. Now try loading something else. Does that work? Quote Jon Hole linkedin.com/in/jonhole
nbaldwin Posted September 13, 2018 Report Posted September 13, 2018 We've just had the same problem. Updated to latest OS a couple of weeks ago, now it fails to recognise the USB drive in any of the USB sockets. Help! If we do a factory restore will it wipe out all of the fixtures? Quote
nbaldwin Posted September 13, 2018 Report Posted September 13, 2018 Leapfrog96 with 7.9.4 USB stick is the Zero88 branded one that came with the desk. Have tried other USB sticks (FAT32) and it doesn't read those either. Have also tried plugging the mouse into the front panel USB but the mouse still works OK. Quote
nbaldwin Posted September 13, 2018 Report Posted September 13, 2018 Also tried copying the .isf files from the USB stick (for safety), reformatting the USB and then copying just one .isf back to it. Still not recognised by the desk. Is there a way to backup our fixtures? We have a big show at the weekend. This couldn't have happened at a worse time Quote
Edward Z88 Posted September 14, 2018 Report Posted September 14, 2018 Hello, With the USB stick unplugged, tap "Other Windows", found top left of the Output Window, and from the drop down choose System Info, then tap System Info. At the bottom of this screen you should see a section labelled "USB devices...". Looking at this section, plug the USB stick in, do you see any change? If so the console is detecting the USB stick. Then tap SETUP -> Save Show -> tap Refresh after 10 seconds, do you now see "Removable Device" appear in Destination Device? Let me know how you get on. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
nbaldwin Posted September 14, 2018 Report Posted September 14, 2018 Thanks Edward. I followed the steps and the device does appear in the USB devices list when plugged in. Hitting Refresh on the Load/Save pages does nothing: still says <No Destination Devices> Neil Quote
Edward Z88 Posted September 14, 2018 Report Posted September 14, 2018 Hi Neil, We'll continue discussing this via email. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
sabah69 Posted October 13, 2018 Author Report Posted October 13, 2018 Hi Thanks for these replies, just back to the forum. I'm still having the same issue. Did you get a resolve Neil/Edward? Cheers Sandy] Quote
Edward Z88 Posted October 13, 2018 Report Posted October 13, 2018 Hi Sandy, OK thanks for letting me know. Did you try Jon’s suggestion... On 8/3/2018 at 6:16 PM, Jon Hole said: Try doing a Factory Restore, save the empty showfile to the USB stick, unplug the USB stick, plug it back in, and then try loading that "empty" showfile back into the console. Now try loading something else. Does that work? Neil tried out our latest beta version, which I believe solved the problem. I haven’t heard from him recently though. Just to confirm, are you finding if you Factory Reset the console, you can read USB storage devices ok, but as soon as you start programming the console USB devices don’t appear? Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
sabah69 Posted October 13, 2018 Author Report Posted October 13, 2018 Hi Edward Just tried Jon’s suggestion and it all seemed ok until I did some programming. When going to save on the same usb it couldn’t be found. I hadn’t removed the stick, and it was recognised and loading previous shows up to that point. cheers Sandy Quote
Edward Z88 Posted October 13, 2018 Report Posted October 13, 2018 Hi Sandy, OK thanks for trying that. If you’re happy to, please send me an email to EdwardSmith@Eaton.com, and I’ll be able to arrange getting you access to the latest beta software. This should solve the problem, and greatly improve the performance of your Leapfrog 96. Alternatively you can of course wait until ZerOS 7.9.5 is released. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
sabah69 Posted October 13, 2018 Author Report Posted October 13, 2018 Thanks Edward, will mail. Quote
LifeChurch Posted December 13, 2018 Report Posted December 13, 2018 Having the same issues, has this been solved? cheers Quote
Edward Z88 Posted December 13, 2018 Report Posted December 13, 2018 Hello, 1 hour ago, LifeChurch said: Having the same issues, has this been solved? cheers I believe we’ve been chatting on Facebook. Please send us an email to support@zero88.com and one of the team will be able to help you out. All the best, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
