With Software version 7.9.4 after booting the console I can not see the patch view so that I can add dimmers. The options available are Add fixtures and fixture schedule.
A dimmer is a fixture, so use the Add Fixture tool and there is a generic section at the top of the list which contains dimmer. You can patch multiple at a time, so you could add for example 24 dimmers in one step if needed.
As Kevin says, use Add Fixtures to patch your fixtures- when adding Dimmers tap Add Fixtures, and then simply tap Next, as dimmer will be pre-selected for you. Add Fixtures is a new and improved, easier to use and more advanced replacement for Patch Wizard. You will then be able to view your patched fixtures in the Fixture Schedule, which is also where you can configure them.
Hope that helps, any questions let us know.
Email Support
