Fader to control the FX speed
danglen
Hi Guys,
Does anyone know how I can use the fader, to control the speed of a moving head moment using Figure of 8 effect?
Here is my process:
  1. Group > Select my moving heads > intensity at 100%
  2. Effect > Figure of 8 > Random Offset (default speed E6 20)
  3. Rec > All attributes to Fader 1
  4. Playback mode > Setup + Fader 1 > Fader Control set to Effect
When I slide the fader only the intensity is activated, how can I control the speed instead please?
Thanks
Dan
Hi Dan,
The process you describe there, should result in the fader both scaling intensity, and the effect speed/size or your lighting state. From your description you have said record "All Attributes". Did you manually tag all parameters in the Record Options pop up? Did you do a Record all/Snapshot (SHIFT + RECORD)?
If you disable Fader controls Effect, does the effect run as expected, or has this been lost?
Your other option on controlling the effect speed with a fader, is to use Speed Override. This control can be found under the Z key on the second encoder,  but can also be setup on any empty Playback. This will then control the speed of the currently viewed playback.
  • 1 month later...
