DramaKing Posted July 17, 2018 Report Posted July 17, 2018 Hi, firstly must say I'm a new flx user, I was completely blown away by the s24 and I made up my mind to buy one within 30 seconds of seeing it. I got to patching, programming palettes and building a cue stack without even breaking out the manual.. I'm not a novice lampy by any means but it's my first time solo with zerOS. I've come up against a minor user induced problem that I'm hoping somebody can help me fix. When i programmed a prism palette I must have tagged the gobo attribute as well and I can't seem to edit or update the palette in a way which looses the gobo1 attribute, I assumed pressing the button in the wheel would untag it which it does but it doesn't appear to 'save' this change when updated. I'm wary of deleting palettes after a cue stack has been created using this palette because I'm sure it will break it.. any pointers greatfully recieved. Sorry for the long winded question. Quote
kgallen Posted July 18, 2018 Report Posted July 18, 2018 Sorry I'm having trouble navigating the Forum at the moment to find a past topic on this, but it will be something like: - Tag the parameter to remove - Turn off Smart Tag - In the Update window, click Remove - OK the Update This is what it is on FLX (full model), not sure how the UI differs on the S24/S48. Hope this gives you something to try. Kevin Quote
