Hi. I am using the fixture editor to create my own fixture. I have a very simple LED controller. it has 8 channels and controls two separate LED strips.
It has 8 channels, and I have set up one virtual to dim. Two problems:
A) I can get one strip on the colour picker but not the other. Is there any way to have two colour pickers for the one DMX address?
B)A would be fine if I could get the two strips to operate as one. But this is also out of reach!
I have had several test runs - how do I delete the incorrect .ift files from the FLX
Thanks - Mark
LED Strip 5.ift
Hi Mark,
Currently a fixture can only have one set of RGB control applied to the colour picker. If you require both to be, I would advise making a fixture for the first set of RGB, and patch 2 of them sequentially to control the fixture.
To Clear unwanted .ift user fixtures, tap SETUP -> Clear Options -> Clear User Fixtures.
Hope that helps
