Hello
What is missing or which I have not yet found how to do (...):
Side Effects (motions / colors / chases)
- More options so that you can have presets in the additional motion options for aotomatic.
Also have more possible color variations (Automatic and LED) and also chases. (Traditional and LED)
In fact when one has the time to program multiple things it is not a problem. (That's what I'm sure I can do with Capture)
But in case the time is lacking it is there to have a few things programmed in addition would be good.
Colors:
Second lack is on the side of the colors and therefore the proposed choices.
- it is for projectors working in Red Green Blue White Amber. The fact that all 5 colors can not be directly taken into account in color presets makes the FLX try to make amber with RED GREEN BLUE BLUE at best ... MAis miss the real amber . And when you go on amber through the encoder wheel, and then you have to play amber and white colors to find the right tone.
So I think an evolution in the future would be that the color mixer can take into account what the projector can do. And currently more and more projectors have the included RGBW + A + UV ...
Preprogrammed positions:
The other lack is to have some preprogrammed positions in the automatic.
There is HOME. But I think having a position at 25 °, 45 °, 65 ° and 90 ° could be a plus. And then a random position that could serve as a basis for an effect. A bit like when you have ACLs running through the scene. Thus a random creation could save time instead of having to position each projector ...
FLX 2 (One day can be a hardware update)
The other big plus would be to have a second video port to be able to have in front of the eyes directly the window of cues on big screen and on the second screen the access to the 4 color windows, effect, etc ...
Saves time and access faster to be more productive.
And finally when to have an evolution of the FLX is to have more encoder wheels, as on Magic Q.
And so to access directly certain settings rather than having to scroll the screen.
the aspect encoder wheels additional could be included in a Wings option with small LCD screen (as on the consoles sounds from Yamaha, Berhinger, Midas and co)
Notice
Last lack, it is listed PDF record, with an updated version to explain all the new features that arrive over the versions. So I think it would be positive to have the opportunity to have a WEB document that can easily be transformed to update the user manual with the software of the FLX.
That's with the summer coming, I will be able to study more fully the functions of the FLX and thus better know it but also started small video films to present this great product in French.
thank you
Eric
Bonjour
Ce qui manque ou que je n'ai pas encore trouvé comment faire (...):
Coté Effets (moouvements / couleurs / chases )
- Plus d'options afin de pouvoir avoir des préréglages dans les options de mouvements supplementaires pour les aotomatiques.
Egalement avoir plus de variations de couleurs possibles (Automatiques et LED) et aussi des chases. (Traditionnel et LED)
En fait quand on a le temps de programmer de multiple choses c'est un pas un soucis. (C'est ce que je vais pouvoir certainement faire avec Capture)
Mais dans le cas ou le temps manque c'est là que d'avoir quelques petites choses de programmées en plus serait bien.
Couleurs :
Second manque c'st du coté des coleurs et donc des choix proposés.
- c'est pour les projecteurs qui travaillent en Rouge vert bleu Blanc Ambre. Le fait que l'ensemble des 5 couleurs ne puissent pas directement etre prise en compte dans les préreglages de couleurs fait que la FLX essaye de faire de l'ambre avec ROUGE VERT BLEU BLANC au mieux ... MAis passe à coté du vrai ambre. Et lorsque l'on va sur l'ambre par le biais de la roue codeuse, et ensuite il faut  jouer en l'ambre et le blanc couleurs pour trouver la bonne tonalité.
Ainsi je pense qu'une evolution dans l'avenir serait que le melangeur de couleur puisse prendre en compte ce que le projecteur peut faire. Et actuellement de plus en plus de projecteurs ont le RGBW + A + UV d'inclus...
Positions préprogrammées :
L'autre manque c'est de pouvoir avoir quelques positions préprogrammés au niveau des automatiques.
Il y a HOME. Mais je pense que d'avoir une position à 25°, 45°, 65° et 90° pourrait un plus. Et ensuite une position aléatoire qui pourrait servir de base à un effet. Un peu comme lorsque l'on a des ACL qui parcourent la scene. Ainsi une creation aléatoire pourrait faire gagner du temps au lieu de devoir positionner chaque projecteur...
FLX 2 (Un jour peut etre une mise à jour matériel)
L'autre grand plus serait d'avoir un second port video pour pouvoir avoir sous les yeux directement la fenetre des cues sur grand ecran et sur le second  ecran l'acces aux 4 fenetres couleurs, effet, etc...
Gains de temps et acces plus rapide pour etre plus productif.
Et finalement quand à avoir une evolution de la FLX c'est avoir plus de roues encodeuses, comme sur les Magic Q.
Et ainsi d'acceder directement à certain reglages plutot que de devoir faire défiler l'ecran.
l'aspect roues encodeuses supplementaire pourrait etre inclus dans une option Wings avec petit ecran LCD (comme sur les consoles sons de chez Yamaha, Berhinger, Midas et cie)
Dernier manque, c'est coté notice PDF, avec une version à jour pour expliquer toutes les nouvelles fonctions qui arrivent au fil des versions. Ainsi je pense qu'il serait positif d'avoir la possibilité de pouvoir avoir un document WEB qui puisse facilement se transformer pour mettre à jour la notice d'utilisation avec le logiciel de la FLX.
Voilà avec l'été qui arrive, je vais pouvoir etudier plus à fond les fonctions de la FLX et ainsi pouvoir mieux la connaitre mais egalement commencé des petits films vidéos pour présenter ce super produit en Français.
Merci à vous
Eric
