Nico6868 Posted June 25, 2018 Report Posted June 25, 2018 Dear all, is there a way to copy a record scene or chase from a playback to another? thanks Nico
Edward Z88 Posted June 26, 2018 Report Posted June 26, 2018 Hi Nico, Yes there is. To Copy a cue, tap the Copy button found under the Z key, then type the cue number you want to copy, tap the Playback’s button that contains this cue, then tap the playback’s button you’d like this cue copied to. For example, Copy -> 1 -> Master Playback -> Playback 1 copies cue 1 from the Master to Playback 1. Chases can be copied to another playback simply by repeating the above process, but with no need to type a cue number first. Alternatively, you can simply re-record your cue. To do this Output the cue by going into it, then tap RECORD, and tap the playback you wish this to be recorded to. For this to work, you’ll need to ensure SmartTag is enabled, as it is by default. To check this, press and hold RECORD, and ensure SmartTag has a red stripe next to it. Hope that helps, any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
