I have some problems with live operating. I want to use the pallets with chases. How do l save a chase on a playback without it remembering the color or position. It doesn work to hold record and disable the color or position.
Hi Tessa,
This is down to tagging. In the record options menu, ensuring Colour, Beam and Position have a Blue stripe next to them will ensure this isn’t recorded. Alternatively, make sure that no parameters other than intensity are tagged. A tagged parameter is displayed as a light blue background in the encoder display. You can tap this display to manually untag the parameter.
You may find the article below is a useful read...
http://support.zero88.com/1014189311
Hope that helps
Product Specialist
Email Support
