ZeuS Posted June 21, 2018 Report Share Posted June 21, 2018 hi, i ve got a problem. i have 24 rgbw light, i set 4 playback with different color setups.(red,white,r+g mix, and 60%white) the problem is when i changing one from another, the colors are fading in instead of switching. and when i pushing the playback fader slowly the colors are jumping to various colors and only on 100% comes the color what i set before. i tried various settings in playback setup without any luck. what am i doing wrong? thanks Daniel Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 21, 2018 Report Share Posted June 21, 2018 Maybe depends how you recorded the playbacks - what information was recorded. Some of the concepts explained in this Knowledgebase article might be relevant (such as you might need to be turning off SmartTag when you record your colour setup playbacks). Have a read and a play with your more specific colour setup and see if it resolves the conflicts: http://support.zero88.com/Consoles/FLX/1014413041/RGB-Colour-Mixing-on-faders-FLX-Series.htm Kevin Quote Link to comment Share on other sites More sharing options...
ZeuS Posted June 21, 2018 Author Report Share Posted June 21, 2018 i just recorded 1playback 100%red on 100% intensity 2playback 100%red 13% green 100% intensity 3playback 60% white 4playback 100% white Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 21, 2018 Report Share Posted June 21, 2018 The cue colour fade time defaults to 3 seconds and are LTP at 5% fader, whereas intensity will be HTP. Does that explain what you're seeing? Did you try the approach in the Knowledgebase article substituting your colours for their RGB? Quote Link to comment Share on other sites More sharing options...
ZeuS Posted June 21, 2018 Author Report Share Posted June 21, 2018 i lowered all the fade time to zero and i am using the desk in ltp mode i dont understand this i am trying to solve this for 6 hours without any luck. i read through the user manual again modifying every setup what seems to be related but the problem is still exists. and now every saved playback will become the last one i dont know why. i save red after i save blue to another one and the first becomes blue as well Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 21, 2018 Report Share Posted June 21, 2018 Reset your desk. Follow the article I referenced. Reproduce their example. Understand tagging/SmartTag a bit. Go back to your original requirement with that new knowledge and programme it and configure the playbacks with the recipe you've learned. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 22, 2018 Report Share Posted June 22, 2018 Hi Zeus, If you are seeing previous playback colours being “overwritten” with the latest used Playback, it sounds like Release on Lower is disabled for the Playback. To change this go into the Playback settings by holding SETUP and tapping the playbacks button, tap Raise and Lower-> Release on Lower -> Enabled. I you then want to be able to cross fade from playback to playback, your best option will be to enable fader controls colour for these playbacks. Again go into the Playbacks settings, and tap Colour under fader controls. As Kevin also suggests, you need to be aware of something called SmartTag if recording a fixture with 0% intensity- SmartTag needs to be disabled to allow you to do this. This can be done by pressing and holding RECORD, and tapping SmartTag so that it doesn’t have a red stripe next to it, or by holding SHIFT and tapping RECORD, to do a record all or snapshot of the current lighting state. Hope that helps, any queries let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
ZeuS Posted June 22, 2018 Author Report Share Posted June 22, 2018 i ve got it the default cue fade time was the problem. now i know thank you for the responses Quote Link to comment Share on other sites More sharing options...
