rowanpaul Posted June 19, 2018 Report Share Posted June 19, 2018 I recently did some programming in anger for a touring play the other day and was reminded of the problem with pressing/activating the "Clear" button being horribly hit and miss. Counted seven seconds at one point between tapping and the LED. Any news on a next software update that was to sort this problem please? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 19, 2018 Report Share Posted June 19, 2018 Hi Paul, We’re not aware of any problems related to this. If programmer data is cleared by pressing the clear button, the LED will go out straight away. The only time this will be delayed is if Programmer Time is enabled (found on the last encoder in the Z key)- in which case the LED will go off after the Programmer Time has completed. Is this what you’re experiencing? Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
rowanpaul Posted June 20, 2018 Author Report Share Posted June 20, 2018 Thanks Edward, that would possibly explain the delay is there a way to indicate to the user that the clear button has been pressed please? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 20, 2018 Report Share Posted June 20, 2018 Hello, As soon as the Clear button is pressed first the selection will be cleared, and if pressed a second time the Programmer will immediately start to fade out using the Programmer Time - this includes fixture intensities and any other parameters. These can be seen fading in the Output Window (SHIFT + VIEW to quickly view this). Hope that helps Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
