ZeuS Posted June 18, 2018 Report Share Posted June 18, 2018 Hi there, I just made a random 10 step intensity (between 100-80) chaser on playback 1 after I made another playback on playback 2 with 3 steps. 1step is 100% on the first lamp. 2 step is 100% on two lamps.3rd step is releasing this cuelist and triggering the first flickering playback. Is there a way to set the intensity of the triggered playback. I mean I starting the 2nd playback with its button what is automatically triggering the first playback. but what happens if i have to modify the triggered playback intensity without making a new one. I hope it's understandable Thanks Daniel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 18, 2018 Report Share Posted June 18, 2018 Hi Daniel, Playbacks triggered from cues will always trigger at their full recorded value, ignoring fader level. If you need this to trigger at a lower level, you can update the steps of your chase in Playback 1, by holding SHIFT+ tap it’s playback button to snap into the step and make the edits. Tap UPDATE and it’s button to save. Hope that helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
