Hi there,
I just made a random 10 step intensity (between 100-80) chaser on playback 1 after I made another playback on playback 2 with 3 steps. 1step is 100% on the first lamp. 2 step is 100% on two lamps.3rd step is releasing this cuelist and triggering the first flickering playback. Is there a way to set the intensity of the triggered playback. I mean I starting the 2nd playback with its button what is automatically triggering the first playback. but what happens if  i have to modify the triggered playback intensity without making a new one.
I hope it's understandable
Thanks Daniel
Hi Daniel,
Playbacks triggered from cues will always trigger at their full recorded value, ignoring fader level. If you need this to trigger at a lower level, you can update the steps of your chase in Playback 1, by holding SHIFT+ tap it’s playback button to snap into the step and make the edits. Tap UPDATE and it’s button to save.
Hope that helps,
