Dangi Posted June 5, 2018 Report Share Posted June 5, 2018 Hello, I've got an urgent question. We would like to run cues with crossfade, not with the "Go" button. I suppose that "Manual Fader 2 way" mode is the way to go here. If I switch to this mode, I can't manually start cues with for example "Go + 5" anymore (which works in HTP master mode), which is not convenient for rehearsals. Is there a workaround or better way which I haven't found yet? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted June 5, 2018 Report Share Posted June 5, 2018 1 hour ago, Dangi said: We would like to run cues with crossfade, not with the "Go" button. I suppose that "Manual Fader 2 way" mode is the way 1 hour ago, Dangi said: If I switch to this mode, I can't manually start cues with for example "Go + 5" anymore Correct - if you choose to use the fader to manually crossfade, rather than the GO button and the programmed times, the GO button stops working. 1 hour ago, Dangi said: Is there a workaround or better way which I haven't found yet? You can select the "Next" cue (Yellow line) using a mouse or touchscreen, and then the fader will fade to that cue Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
kgallen Posted June 5, 2018 Report Share Posted June 5, 2018 1 hour ago, Dangi said: I suppose that "Manual Fader 2 way" mode is the way to I don't see that ZOS-8363 is fixed in 7.9.4 (Release Notes) so I'm not sure if 2-way fader is going to work? Quote Link to comment Share on other sites More sharing options...
Howartp Posted June 5, 2018 Report Share Posted June 5, 2018 27 minutes ago, kgallen said: I don't see that ZOS-8363 is fixed in 7.9.4 (Release Notes) so I'm not sure if 2-way fader is going to work? kgallen, we can't see whatever you posted under your sentence there? Quote Link to comment Share on other sites More sharing options...
Dangi Posted June 5, 2018 Author Report Share Posted June 5, 2018 Well, thanks for answers! Problem solved for now, since the guest technician is ok to work with the Go-Button. A Workaround that came to my mind is to save each cue on a playback fader and program each playback button to trigger a "go", so we could have both worlds in the future. @ zero88: Maybe it could be possible to let us use the Go-Button when in Manual-Fader-Mode? I don't see any reason why it is switched off. Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 5, 2018 Report Share Posted June 5, 2018 1 hour ago, Howartp said: kgallen, we can't see whatever you posted under your sentence there? It's a link to the beta test forum for those that can see it. Peter, I thought you were a beta tester too? Kevin Quote Link to comment Share on other sites More sharing options...
Howartp Posted June 14, 2018 Report Share Posted June 14, 2018 On 6/5/2018 at 8:26 PM, kgallen said: It's a link to the beta test forum for those that can see it. Peter, I thought you were a beta tester too? Kevin Apparently not! I am for various forums/products, but not for Zero88. Quote Link to comment Share on other sites More sharing options...
